TA Starting Handle.
prharris25
TA Starting Handle.
Post by prharris25 » Mon Sep 08, 2014 11:39 pm
Hope somebody can help please. Just making up a starting handle for my TA and need to know the accurate measurement from the chamfered end of the handle to the engagement pin......probably something like 15mm but would like a reasonably accurate fix on this so I can get it right first time! Many thanks. TB/C probably the same.
Paul.
dirk w dondorp
Re: TA Starting Handle.
Post by dirk w dondorp » Tue Sep 09, 2014 11:13 pm
Hi Paul,
mine measures 19 mm from end of shaft - middle of hole.
Suggest you put your unfinished shaft in the dognut on the crank and take controll measure there?
Cheers
Dirk
Last edited by dirk w dondorp on Tue Sep 09, 2014 11:36 pm, edited 1 time in total.
prharris25
Post by prharris25 » Mon Sep 22, 2014 11:26 pm
Thank you Dirk, very grateful.
Apologies for lateness in replying as I have been on holiday.
Kind regards,
Paul.
