Hub bearing
JTPAKI@aol.com
Hub bearing
Post by JTPAKI@aol.com » Sun Feb 27, 2000 2:45 am
Hello everyone
Ok, I am replacing the bearing in the hubs on the rear axle of my TC. Now
as I understand it this is a simple tangential load bearing. My question is
that the new bearing is different on either side. The old bearing is the
same on both sides. Does it matter which way the new bearing goes into the
hub? I think not maybe, any opinion.
I made a quick web page that has the pictures of each bearing old and new at
http://hometown.aol.com//jtpaki/bearing.html">bearing pictures
for those of you on AOL
http://hometown.aol.com//jtpaki/bearing.html (for the rest of you)
The old bearing is: R&M of England part # LJ40
The new bearing is: KOYO of Japan part # 72088GC3
thanks
Joe Potter
ROGER FURNEAUX
Re: Hub bearing
Post by ROGER FURNEAUX » Sun Feb 27, 2000 8:08 am
My reference books do not cover Japanese, but a 7208 is a THRUST bearing, of the sort found either side of the Crown-wheel (which are 7207, one size down).
They are totally unsuitable for the rear hubs, for which the correct bearing was the R & M LJBL40 which had 12 or 13 balls. modern equivalent is the M208, although many people fit the cheaper 6208 which only has 9 balls.
It would help to know who recommended these brgs. to Joe - they need to brush up on their knowledge!
ocTagonally
Roger Furneaux
JTPAKI@aol.com
Re: Hub bearing
Post by JTPAKI@aol.com » Sun Feb 27, 2000 8:28 am
Actually Roger, I just took them down to the bearing shop that my business utilizes, and said I need couple of these (old bearing), and this is what I got, so nobody to blame but me. Now you say the correct bearing is the R & M LJBL40. The number on the old bearing is R&M LJ40. Is this the same bearing? or is what was in there incorrect? Also, as far as a part number of the correct thing to get, should I ask for a R&M M208 ?
Joe Potter
taterry@aol.com
Re: Hub bearing
Post by taterry@aol.com » Sun Feb 27, 2000 10:25 am
Joe, I would highly recommend you get the bearing with the most balls and get a "sealed" bearing which is packed with grease...don't for get the "sheims"....
Terry
PMS GB Ltd
Re: Hub bearing
Post by PMS GB Ltd » Mon Feb 28, 2000 4:46 pm
Message text written by "Roger Furneaux"
Roger, you are right, 7208 is an SKF reference number BUT
- the KOYO of Japan part # 72088GC3 just might be a thrust too, but equally may be correct for the non thrust rear hub (I just dont know) - I've been led astray in the past by numbers (including bearings) from different manufacturers being the same/similar - but for totally different products!!!
A case of needing to check the specification carefully!
Clive Sherriff
