Seat Adjustment Track
JTLee
Post by JTLee » Wed Sep 23, 2015 8:47 am
1949 TC - how should I position the seat adjustment track on the floorboard to screw it down - should the rails be as far back as the can be positioned or some distance forward of the rear ramp. Installing new floorboards and no old ones to look at for positioning the rails. Thank you for any help. J Lee
Re: Seat Adjustment Track
Post by frenchblatter » Thu Sep 24, 2015 9:38 am
I'll measure my old floorboards in the morning. I'll need to so I can mark the new ones.
Post by frenchblatter » Fri Sep 25, 2015 6:45 am
Having spent 20 minutes looking for an email about measuring the floor I remembered it was on here.
OK, the RH floor has the three hole bracket nearest the tunnel at:
8cm from the tunnel edge and 64.7 cm from the rear. This is the hole that is nearest the tunnel edge. I couldn't measure the outside as the floor has disintegrated so much it's difficult to tell what was a screw hole from all the other holes.
8cm converts to 3 5/32" and 64.7" is 25 15/32 (call it 25 1/2")
Hope that helps. If you want to email me I'll send you a picture.
JTLee
Post by JTLee » Fri Sep 25, 2015 7:25 pm
Thank you - I should be able to take it from here - cheers - James Lee
JTLee
Post by JTLee » Fri Sep 25, 2015 7:30 pm
JTLee
Post by JTLee » Fri Sep 25, 2015 7:32 pm
Email picture please rmrmaintenance@aol.com tnx
JTLee
Tim Jackson
Post by Tim Jackson » Mon Sep 28, 2015 3:54 am
This topic was covered last year (Apr 2014):
viewtopic.php?f=2&t=293
1946 TC0999 / XPAG 1638
restore note
Post by frenchblatter » Mon Sep 28, 2015 6:46 am
Surely, if you have the backrest in an upright position, the squab sliders right back then that's where the hinged brackets will fit. Then the seat can move forward.
Or am I missing something?
Tim Jackson
Post by Tim Jackson » Mon Sep 28, 2015 1:40 pm
Seat design changed around Sept 1946 (Sherrell pg 56 & 66). Early seats had a full length seat back down to the floor and a shorter seat base. I think the track position is the same. Open to correction
restore note
