I need a top frame (hood frame) for my early TC (#TC 0275) Also need front two side curtain frames.
Thanks.
Ed Dunn
eedunn@home.com
800-290-3751
TC top frame needed
- Geoffrey WHEATLEY
Re: TC top frame needed
Try Brown and Gammon in the UK they are your best bet, helped me with my very early 45 TC. Do you have the original frame or any thing of it like the metal struts? If so you can get a replacement made...Side curtains are another matter!
Regards Geoff
Regards Geoff
- JohnHWSteedman@aol.com
I can't supply you with a frame, but I have an unrestored one from TC0301, which I am happy to measure, etc. if you need dimensions. As you will know from Sherrel's book, early frames have some unique characteristics, as do several other components, - I have still to find a scuttle that looks like mine (the tool box and battery box are spot welded into the rest of the scuttle, which I assume is a TB leftover); although you can see the same construction in the photo on page 45 Graham Robson's "The T Series MG" (if you have sharp eyes!)
regards,
John Steedman
regards,
John Steedman
