checking comp ratio
tone
checking comp ratio
Post by tone » Mon Nov 30, 2020 12:04 pm
any ideas how I can check the compression ratio of an engine please?
was thinking of upping the supercharger fully to give a bit of a boost in power, bottom end is all good had head sorted a while ago to unleaded so think it should be ok, but would be useful to have a starting point to measure
thanks
Re: checking comp ratio
Post by Tom Lange, MGT Repair » Tue Dec 01, 2020 2:33 am
If you know the bore diameter, the piston type (flat-top or domed), and recorded the head thickness when you did that work, you can get a pretty close approximation.
