I rebuilt my engine in 2018. I didn’t really have any oil pressure issue prior so I just cleaned up the pump cover, removed an extra gasket and replaced the pressure spring. I set the clearances correctly. Upon completing the rebuild I had a very difficult time getting oil pressure. Since then, every time I change oil, I need to pull the filter line off the top of the pump and inject a shot of oil directly into the pump with a squirt can. I put the line back on, start the car and get pressure almost immediately.
I am pulling the engine to resolve a timing cover leak and plan to replace the pump gears and bushings while I have easy access. Im hoping this will resolve my prime loss problem or should I be looking elsewhere or doing something else while I’m in there?
Losing oil pump prime after oil change
Ken Klemmer
1948 TC 5510
1948 TC 5510
Re: Losing oil pump prime after oil change
Sounds like an air leak somewhere possibly? Maybe the intake tube to oil pan?
That’s a good theory... I’ll look when I pull the pan. Strange that one squirt of oil fixes it,
Ken Klemmer
1948 TC 5510
1948 TC 5510
