Carpet fixings.
Carpet fixings.
Post by jddevel » Wed Mar 03, 2021 6:13 am
Working on the bulkhead/firewall. Search on the internet has failed so far to provide a source for the part that goes in the actual carpet. The existing fitting in the bulkhead is the "pillar/spike /turret type. As now is the opportunity to change the fitting in the bulkhead unless a source for the original type can be found any advice suggestions please.
Re: Carpet fixings.
Post by Duncan M » Wed Mar 03, 2021 1:02 pm
"Lift The Dot"
Re: Carpet fixings.
Post by jddevel » Thu Mar 04, 2021 5:25 am
Thanks Duncan Now I know what they are called it was easy to find. Appreciate your help.
SteveT
Re: Carpet fixings.
Post by SteveT » Sat Mar 13, 2021 11:32 am
I fitted a longer ‘male’ to the ones where the carpet doubles up. Made life easier.
TC 6927
