slow running cable
TCTrev
slow running cable
Post by TCTrev » Sun Mar 14, 2021 9:50 am
before fitting inner cable to slow running lever should you be able to move inner cable very essay by hand , all so how do you set it all up its a 1948 tc
Re: slow running cable
Post by Steve Simmons » Sun Mar 14, 2021 10:01 am
It should move smoothly and relatively easily through the housing. There may be some friction once you bend it around all the corners between the dash panel and the carbs, but it should not be tight. The dash knob should turn easily with two fingers.
When you connect it to the carb lever, leave a very slight gap between the adjustment screw and the lever, to ensure that the throttle returns fully.
Here are some photos on the setup:
http://www.mg-tabc.org/library/slow_running_control.htm
And here is a useful video:
https://www.youtube.com/watch?v=dVpSc_-Ft2g
TCTrev
Post by TCTrev » Sun Mar 14, 2021 10:31 am
thanks i will have a look at it next couple of days
