Spark Plug Thread Size
SteveW
Post by SteveW » Sun May 02, 2021 9:53 am
Just a quick and hopefully easy question to answer:
What is the thread size for the spark plugs on a TC? The reason for asking is that I need to clean up the spark plug hole threads on my cylinder head and I need to know what size tap to buy.
Re: Spark Plug Thread Size
Post by Steve Simmons » Sun May 02, 2021 10:02 am
If I'm not mistaken, it's 14mm x 1.25.
Post by frenchblatter » Mon May 03, 2021 3:08 am
Agreed,
There are only 3 sizes, 10mmm, mainly for race engines, 14mm for the vast majority and 18mm for tractors/industrial engines.
Or are there more that I've missed?
STEVE, I've got a tap, don't go buying one for a one time use. I can drop it down tomorrow if you want.
SteveW
Post by SteveW » Mon May 03, 2021 7:59 am
Hi Norman,
Thanks for the offer, if you're passing by then please do drop it off. I can then give you back the last thing that I borrowed off you :)
I've got to be heading over to the observatory at about 4:30pm though.
SteveW
Post by SteveW » Sat May 08, 2021 1:55 am
Thanks to Norman who went to the trouble of making a tap from an old spark plug when he found that he didn't have the correct size, the plugs now all fit as they should.
What I should have done was to check the depth of the holes before I bolted the cylinder head on. As near as we could measure in-situ, heads with a casting number of 22952 use short reach plugs, but perhaps someone could confirm.
