t-series grill shell identification
Rickwilson
Post by Rickwilson » Mon Nov 29, 2021 10:37 am
I understand that the hole for the handcrank is fully opened at the bottom on TC's. I've been told that TD's have a partially opened handcrank hole. I have seen TC's & TD's with fully closed circular handcrank holes. does anyone know the correctness of these 3 different grill shells?
Re: t-series grill shell identification
Post by Steve Simmons » Mon Nov 29, 2021 11:37 am
To my knowledge there are two. The TC is open on bottom, TD is closed. There are also some aftermarket shells out there that may have that area beefed up a bit. A lot of TC shells were replaced back in the day when they cracked at the bottom, and the replacements were the newer, stronger TD type.
Rickwilson
Post by Rickwilson » Mon Nov 29, 2021 11:47 am
Okay, so apparently the units with fully closed circular crank holes are aftermarket reproductions. thanks for the info Steve>
Tom Lange, MGT Repair
Post by Tom Lange, MGT Repair » Tue Nov 30, 2021 5:54 am
Or are TD shells installed on a TC - not uncommon either.
