Bolt for the Starter MGTC
- Uwe Harlos
Hello all,
I think in my startermotor in the TC is a wrong bolt to hold the two cables.
Can everybody give me the right size?
Thanks very much and be save.
Uwe
Uwe
Re: Bolt for the Starter MGTC
Hi Uwe, I think you may need to explain your issue a little clearer as I'm not sure which bolt you are referring too as there is only ONE cable from the starter motor to the dashboard
I wonder if he means the battery and ammeter cables ?
Not very clearly shown in this pic... .....but my ammeter lead is secured to the battery cable with heat-shrink sleeving, and is not held by the clip.
Don't remember the bolt size or thread form.
The battery cable is the one secured to the starter with the clip. The ammeter cable is usually routed alongside the battery cable for neatness, although not normally secured with the clip.Not very clearly shown in this pic... .....but my ammeter lead is secured to the battery cable with heat-shrink sleeving, and is not held by the clip.
Highly recommend viewing Doug Felton of the frame up video
https://www.youtube.com/watch?v=Fq_1yHFjpgM
- Uwe Harlos
Hello all,
I mean the Bolt how goes in the Starter on the front.
In the picture from amtijam where the batteriecable and the amperecable were
hold in the starter.
Thanks for a answer.
Sorry I have no picture.
Regards
Uwe
Regards
Uwe
Hi Uwe, to the best of my knowledge, that bolt is a 5/16-24 UNF.
The unified thread standard wasn't adopted until 1948 and I doubt if it appeared on the TC at all. The thread form is more likely BSW or BSF - although since it's threaded into the block it might still be Metric as on the original Hotchkiss.
I believe what he's referring to is the bolt that holds the battery cable to the starter, not the bolts that hold the starter to the block. My recollection says it's UNF even though a British thread would seem more likely. When I get a chance, I'll pull a spare starter out and double check.
Edit: Yes, double checked the spare starter and it is indeed 5/16-24 UNF.
It could well be UNF. UNF/UNC adoption was an early (late 40's) attempt at uniformity. The thread was in existence well before the adoption date. The head of the bolt in question does not fit any of the normal British wrenches. While 14mm wrench is a very (overly) tight fit on the head, 9/16" fits just right. If it is UNF, that would seem to make it 3/8" UNF. But, I have not examined the threads, because it is too difficult to remove when the starter is mounted in the car.
- ROGER FURNEAUX
It is indeed 5/16" UNF - I just checked with a new contact plate. This of course is made of brass, so there is a danger of damaging it with the wrong size bolt, such as 5/16" BSf or "Mad Metric" 8x1.0mm (which is very close!).
Roger
Roger
So the obscure point of originality on that bolt is that a modern (standardized) replacement bolt of 5/16" UNF will have a 1/2" head, while the early (prior to standardization) original 5/16" UNF bolt had a 9/16" head.
Ah - I have obviously misunderstood the OP's question (these senior moments are becoming more common
) The bolt he's referring to is that arrowed red rather than that arrowed yellow.
Apologies.
Apologies.
- Uwe Harlos
Hello all,
thanks for the answers.
I order today a 5/16 UNF-24.
Regards
Uwe
Regards
Uwe
- ROGER FURNEAUX
Roger
Roger
- Uwe Harlos
Hello all,
I want give you a feedback.
Yes it is a 5/16 UNF.
Thank you
Uwe
Thank you
Uwe
