MG TC 1948 steering column adjustment
BASILPEA
Post by BASILPEA » Thu May 05, 2022 3:59 am
Hi All - is it possible to adjust the column up and down there is a nut/bolt on a bracket which looks as it should adjust. I have undone the bolt but cannot raise the column. Any help much appreciated - thanks Bas
Re: MG TC 1948 steering column adjustment
Post by Ray White » Thu May 05, 2022 5:32 am
Bas. The column can't be adjusted for length but there is a little bit of up/down adjustment at the bracket. You might be able to steal a bit with the position of the wheel on the column splines. If the column is presently fixed in place, I would suggest you loosen the bolts at the steering box so you don't put strain on the column. Of course, remember to tighten them agin when you are done!
Hope this helps,
Ray.
BASILPEA
Post by BASILPEA » Thu May 05, 2022 10:20 am
Thanks Ray much appreciated
