Rubber, bonnet to cowl
- ferricsteed
Easy questions, what type and size screws hold the rubber to the cowl which the bonnet rests on? Oval head screws without washers? Distance between screws?
I threw the old rubber away before measuring the distances.
Tim Bloomfield
End of winter in Louisiana
Tim Bloomfield
Re: Rubber, bonnet to cowl
They did not use screws. A type of tack.
Specification 259 calls for 24 off Panel pins 3/4” long.
You are likely better off using pins that won't rust.
- ferricsteed
Thank you! Pins it will be. Great pic showing pins. I'll install 24 pins equi-distant.
Similar to a typical finishing nail in US, but shorter. Like these:
https://www.homedepot.com/p/Everbilt-18 ... lsrc=aw.ds
