Lucas fog lamps
Lucas fog lamps
Post by Ray White » Sun Mar 12, 2023 4:46 am
Hello everyone. I would like to know how to date Lucas fog lamps. I have an early Lucas SFT 462 for my '49 TC. The original, however, has been replaced with a later type.
What I am trying to establish is exactly when did Lucas go from the early to late design of lens.?
Thanks, Ray.
Re: Lucas fog lamps
Post by antijam » Sun Mar 12, 2023 11:35 am
Anders Clausager states in his book 'Original MG T series' that the fog lamp was changed in 1948 from a Lucas FT27 to the SFT462 from TC/4739 on. Clausager doesn't specify when the SFT 462 glass changed from the 'stepped reflector' to the ribbed design.
Re: Lucas fog lamps
Post by Ray White » Sun Mar 12, 2023 2:37 pm
The issue is a minor detail that should not worry me but for some reason it is like an itch I can't scratch. My car is 1949 and I don't know if it should have an early or late model SFT 462.
A while back I bought an early stepped reflector Lucas SFT 462 in need of restoration. The fog lamp then suffered a freak accident; smashing the ribbed glass. I have had the lamp restored but have only been able to find a later lens with cross hatching.
Complete early fog lamps are occasionally available but for a considerable sum. I don't know if I should keep looking for a replacement early lens or stick with what I have.
Re: Lucas fog lamps
Post by stephen stierman » Mon Mar 13, 2023 1:22 am
Ray, I believe cars from sn. 5000 down had the FT27, your car would be correct with the SF462 as is.
Re: Lucas fog lamps
Post by Ray White » Mon Mar 13, 2023 3:37 am
Hi. Stephen.
Yes, the Lucas SFT 462 fog lamp is correct for my car but there were two versions. The earlier model had a stepped reflector and simple vertical flutes. The later version eschewed the stepped reflector and had cross ribbing in the glass.
What I want to know is exactly WHEN did Lucas make the change. If it was before 1949 (chassis 10,030) I can use the later glass and reflector which I have. If the change was made after my car was built then I am looking for an earlier glass to replace the broken one.
Re: Lucas fog lamps
Post by stephen stierman » Mon Mar 13, 2023 6:12 am
I apologize Ray, I was misreading your request!
Re: Lucas fog lamps
Post by Steve Simmons » Mon Mar 13, 2023 10:12 am
I thought those later lenses were replacement units from the 50s, but I could be mistaken.
Re: Lucas fog lamps
Post by Duncan M » Mon Mar 13, 2023 11:20 am
Was one lens/reflector and bulb for driving lights and the other lens/reflector and bulb for fog lights?
Re: Lucas fog lamps
Post by Ray White » Mon Mar 13, 2023 2:48 pm
You may be right because the Lucas catalogue only specified one version of SFT 462. The only problem with the idea is that a different reflector is also found on what I had been led to believe was a later version. Having said that, stranger things have happened.
It would be interesting to establish the facts once and for all.
