dashboard trim
dashboard trim
I am about to fit the rolled edge to the new dashboard and would like any advice on how it's done.
For example, should I use small chrome/brass screws? if so, what size?. OR brass nails?
Also, how many are used? How far apart?
Should I drill holes first ...and what size?.
As I am only going to get one shot at this I want to get it right...
Any advice would be greatly appreciated.
Thanks, Ray.
Thanks, Ray.
Re: dashboard trim
I refer you to your previous post
I'd suggest forming the strips to the dash contour before drilling the holes for the screws; if done first the strips will tend to kink when bending.
Re: dashboard trim
On my TA there are steel nails about 4" apart except at the extreme curved ends where they are 2" apart.
It appears to me like the factory workman did not pre-drill holes, he just hammered the nails right through the aluminum. In one place he must have did one wrong because there is another nail close by.
Re: dashboard trim
My apologies, Antijam. I am getting old and memory not what it was. Your patience is appreciated..
Rob. I would probably not do it like that...
THANKS GUYS.
THANKS GUYS.
Re: dashboard trim
Let me correct myself. The material is plated brass, not aluminum.
It is a very thin plate, and my steel wool polishing today cut right through it.
As such, the workman probably did not just hammer the nails through, but as the spacing is random, I think it was not done by a machinist in a drill press on flat stock. I suspect the body worker formed the piece against the dash while he attached the nails, and may have used an alloy steel punch to punch the holes.
- Tim Jackson
Re: dashboard trim
Yes thank you. Like Antijam you have already posted this to an earlier request for help that I had forgotten about.. Sorry for that.
Ray.
Re: dashboard trim
Apparently in the TA days it was different, nothing but flat head steel box nails all around.
Some of the holes in the molding are swaged or flared downward, like you get from punch work.
But round or pan head self tapping screws makes more sense. I think that is what I will do.
Re: dashboard trim
