The battery was then installed with the correct polarity. The car starts, runs and drives fine, but the ignition/red light stays on. I assume this means the charging system is not working? However, by checking voltage output from the dynamo, it appears that it is generating about 13+ volts. Only issue is that the red ignition light remains on while the engine is running. The car is wired positive earth.
I've been told to ?polarize? the voltage regulator by (and this is primarily where I'm confused) jumping or touching (w/something like a screwdriver) one or two (??) of the terminals of the VR. That's intimidating to me, but I'm willing to try. I've also been told to replace the VR. That advice coming from someone who feels I've fried the present VR. Does that sound right? Any help would be appreciated. Thanks so much.
