TC carpets
TC carpets
Post by Ray White » Wed Jul 03, 2024 12:10 pm
Not having done this before, please could someone tell me if the seat runners should go in first or should the carpets be fitted first with the runners on top?
Thanks.
Re: TC carpets
Post by Tom Wilson » Wed Jul 03, 2024 1:06 pm
rear carpets, then the seat runner hinge slides into the L cut in the carpets.
Tom
Re: TC carpets
Post by Ray White » Thu Jul 04, 2024 2:09 am
Thanks Tom. I would be interested to know if anyone has used sound deadening material on their car and if it was worth doing?
BCBryan
Re: TC carpets
Post by BCBryan » Thu Jul 04, 2024 8:22 am
When taking apart TC6984 I found this sound deadening which I thought might be original- later I realized this car had it's rear section replaced as the back wooded panel of the side curtain box had rotten out. Not sure if this is correct of not but I plan to put a more modern sound deadening material with an adhesive backing over the rear wheel arches.
Bryan.
Re: TC carpets
Post by Duncan M » Thu Jul 04, 2024 11:24 am
Example of effective TC sound deadening-
Re: TC carpets
Post by Ray White » Sat Jul 06, 2024 2:32 pm
How many ears do you think I have???
I thought of fitting sound deadening from the the toe board back because I have a stainless steel extractor manifold and pipes that may well become a bit tiresome on a long trip. I am not just thinking about me but my passenger. The down side is that it is just more weight to lug about.
