Gas Tank Leak Detection
ferricsteed
Post by ferricsteed » Thu Dec 03, 2015 8:08 pm
I have a TB with a slightly leaky 3 year old TC gas tank. The TC sending unit leaked though the usual spots but also the crimped right side panel half way up developed a slight seep which ruined the paint. I removed the sending unit and welded up the hole and the threaded holes. I brazed the seeping area. Before I repaint the tank, how do I check for leaks? Fill with alcohol? Fill withgasoline and go through the degassing process? Hopefully there are better ideas out there..
Tim Bloomfield
TB0613
Louisiana
Re: Gas Tank Leak Detection
Post by Steve Simmons » Thu Dec 03, 2015 8:16 pm
Just a thought, but you could have the tank pressure tested at a radiator shop. If it's airtight then it's certainly liquid tight. I just had an antique tractor tank tested in this manner. Test and repair was a whole $20.
ferricsteed
Post by ferricsteed » Tue Dec 08, 2015 11:50 am
I used my air compressor and pumped tank up to 10 psig. With a little soapy liquid, the bubbling showed the leaks quite well. So much for my welding prowess. How best to seal the pin holes in the welds? I plan to re-weld each pin hole and keep checking. Would just smearing Seals All or if soldering will wick into the pores may be a better solution?
Post by stephen stierman » Tue Dec 08, 2015 2:22 pm
I welded a patch on a damaged tank on my Morgan, very tough to seal the pin holes. Ended up taking it to a radiator shop and they soldered it properly, that is the best way. I have used JB Weld on small leaks in seams as it does not appear to be affected by fuel.
Post by frenchblatter » Tue Dec 08, 2015 9:24 pm
You've just reminded me. 10 years ago I had a slight drip of petrol from my Caterham ali tank. It had been rubbing on the chassis. As it was the depth of winter and below zero (the drips of fuel had frozen, which is why I noticed it), I slapped a bit of epoxy resin in the pin hole. Although the tank has been out several times since and I have a TIG welder I've just forgotten about it. It ain't broke, don't fix it.
ferricsteed
Post by ferricsteed » Fri Dec 11, 2015 2:08 pm
Update: Thanks for the suggestions. Steve, I pressured it up at home with an air compressor ~15 psig (with one suction line open). The soap bubbles clearly showed me how bad a welder I am. I took my time and through multiple iterations, I MiG'd the holes closed. Lots of welding and grinding. I am a much more proficient welder than when I started.
Now to tackle the rusty quarters............
Tim Bloomfield
TB0613
70F Louisiana
Rocketsled
Post by Rocketsled » Thu Dec 17, 2015 7:22 am
Wicking type thread locker is used to seal porous welds. The Loctite product is 290, A.K.A. "Afterlock'
since it is also used to thread lock fasteners which have been tightened already.
Rocketsled
