Newbie Brake Maintenance Question
rstarkweather
Post by rstarkweather » Sun Aug 25, 2024 12:49 pm
Bleeding the brakes on my TC. All went well.
The "Instruction Manual" says to "keep (the m/c) topped up to within one inch of the cap". Does this mean to within one inch of the top of the threads for the cap, or within one inch of the top of the larger diameter supply tank below the threads? If the former it basically means another 1/2 inch of fluid level.
Just don't want to overfill the supply tank.
Re: Newbie Brake Maintenance Question
Post by Duncan M » Sun Aug 25, 2024 1:32 pm
I fill it so the level is below the neck.
Post by Steve Simmons » Sun Aug 25, 2024 3:39 pm
So long as the level is above the shield in the MC, you have enough. The actual level isn't critical, it's just a reservoir of extra fluid. Do leave a bit of space at the top or you run the risk of some squirting out the breather hole when you release the brakes.
rstarkweather
Post by rstarkweather » Sun Aug 25, 2024 3:45 pm
Thanks, Steve. I was thinking just above the shield as well.
