TC Starter Motor Question
SteveW
Post by SteveW » Fri Nov 29, 2024 12:43 pm
My starter motor had a cover plate over the place where the pull switch normally is. I have a pull switch, so I took the cover plate off and it looks like someone has soldered a washer between the terminals to permanently electrically connect them. The only reason that I can think of as to why anyone would do this is to install a push to start switch elsewhere in the circuit (e.g. on the dashboard).
Has anyone come across this before? Presumably, it's just a case of removing it and installing the correct pull switch.
Regards
Re: TC Starter Motor Question
Post by Steve Simmons » Fri Nov 29, 2024 12:45 pm
Someone probably installed a push button start, or TD/TF/MGA style pull switch. It could have even been used on a Wolsely or other car that used the same starter but with a different rear plate. I'd just remove it, get the plates smooth and flat again and put the switch on. New contact plates are also available.
Mick bibby
Post by Mick bibby » Sat Nov 30, 2024 12:19 am
I’ve had the same problem! An old half penny
