ok so i am debating a rebuild on my TA engine,
I have the block, head, crank, cam, intake Carbs and exhaust Manifold,
I am missing the rods, pistons, timing gears and oil system,
looks like MGBits can sell me oversize pistons, and rings,
Bill Davis shows a nice picture of a aftermarket rod, i am assuming with standard big end bearings, but no source,
if i go that route can i avoid the white metal bearings, and use typical shell bearings?
i am thinking its 3-400 US to machine the block, and 3-400 to machine the head, and 300-400 to machine the crank,
What i am wondering is if any one has a US source for the gaskets, timing gears and chain, and rods and pistons
any input would be great, it seams a shame to dump all this for an XPAG when its 80% there?
thanks Justin
ENGINE REBUILDS
Re: ENGINE REBUILDS
Try MG Octagon club for the timing gears and chain. They are listed in the current price list.
www.mgoctagoncarclub.com/
Download the price list and you will see on page 7 the following...
SBE076A Crankshaft timing chain sprocket - MPJG £122.62
SBE076C Cam gear timing chain sprocket - MPJG £159.92
The chain is also listed.
You might try Barry Walker for pistons and rods and oil parts. http://www.barrywalker.com/
Good luck
Mike
Good luck
Mike
Re: ENGINE REBUILDS
Also check eBay - I saw that Martin at Abingdon Spares recently listed a set of TA rods. I would contact him directly.
- AbingdonSpares
Re: ENGINE REBUILDS
HI Justin, Yes I do have the parts you need give me a call Monday at Abingdon Spares 800 225 0251 or PM me your number and I will give you a call.
Thanks, Martin
Thanks, Martin
- Justin the brit
Re: ENGINE REBUILDS
so Martin was able to help me out with the pistons and rods, and the oil pump assembly,
can anyone recommend a shop to remetal the rods and machine the crank and block to match?
I am assuming the machining, and the remetal work have to be done together so they match correct?
