TC air filter modification
PeterSprot
Post by PeterSprot » Sun Jan 17, 2016 7:48 am
Hello,
I live in Suffolk UK and I'm new to this forum and also new to TC's having just bought one a week before Christmas.
Mine is TC1388, it has two flat air filters and although it looks quite nice I do have the original cylinder filter and the castings which hold it. I was told that the original filter does not breath very well which is why it has the pancakes. I heard that the original canister can be modified to hold a modern air filter. Does anyone have a detailed description how to do this and which air filter to use.
Thanks for any advice offered.
Regards
Peter Sprot
Re: TC air filter modification
Post by Marv » Sun Jan 17, 2016 8:20 am
There have been a number of Modifications put forward for the TC air filter canister. Some are much more involved than others.
http://www.mg-tabc.org/library/T-airfilter-2-K%26N.htm
(somewhat complicated and involved)
http://www.tcmotoringguild.org/techinfo/TClinic-6.pdf (requires adobe reader or nitro reader to open!)
(relatively minor in scope of modification and uses inexpensive over the counter air filters) My preference!!!
There are one or two other approaches I've seen but these two will give you an idea of whats involved!
Good Luck and welcome to the forum
Marv TC5141
PeterSprot
Post by PeterSprot » Sun Jan 17, 2016 12:06 pm
That is really helpful.
Thanks very much.
Regards
Peter
Post by frenchblatter » Sun Jan 17, 2016 12:42 pm
Peter, give NTG a ring. They're near you and are very helpful.
Post by stephen stierman » Mon Jan 18, 2016 3:12 pm
In the Technical Articles on this site under fuel is a description of how to modify the standard filter canister so that a large paper element from a Porsche 912 will fit inside. I have done just that with good result and found that the system will now filter out debris smaller than bits of gravel or dead flys.
