Post
by Warmuthb » Mon Sep 28, 2015 7:02 am
Rich:
I used to run a body shop for a Lincoln/Mercury dealership. However, for an antique or restoration things are different.
Are you doing the disassembly and reassembly? Is there bodywork to be done, i.e. Rust, dents, etc?
Labor will be the most expensive part, however that doesn't mean paint is cheap, because generally speaking, it is not.
Re: paint. You can spend $1,000 for paint and supplies ( for a modern base coat/clear coat job with brand name paint).
Or, you can buy a gallon of single stage (no clear coat) urethane enamel ( which is hardened with a catalyst) from the Internet for about $100. I have done both with my cars. Depends on what you want. Show car or nice original style driver. In any event, a show car finish WILL always cost more because there is more labor in the job. An MG "T" car can't be properly painted unless it is taken apart.
If you do the dis-and reassembly, there is no body work to fix, and you don't want a show car finish, just a real nice job; then in addition to your paint and supplies cost ( supplies= thinners,tape, wax and oil removers, sandpaper, primers,etc); then multiply that cost by 4 and it should get you in the ballpark, I would think. As an example: $2,000 for paint and supplies =$8,000. Whoever you choose to do the work, talk to their former customers and look at their past, and recent work. Stay away from anyone who won't give you this info. By the way, primers are near as expensive as paint and with a primer/surfaced ya wind up sanding most of it off! It is necessary however to get the surface smooth for the paint topcoats. Remember this: paint doesn't hide anything! That's why the painting prep and labor is so expensive.
Good luck
Brian W.
