TA Air cleaner mounting
- martinjames
My TA came with two pancake air filters bolted on. I have purchased a new original format canister air cleaner and manifold, but there does not appear to be any way I can attach the manifold to the carbs as there are no attachment points on the manifold. Is there a part that goes between the manifold and the carbs as I cant find one in any parts catalogue?
Re: TA Air cleaner mounting
I think you mean the red bar in the photos. Goes between the inlet manifold and the air intake.
Its made of 3/4 by 1/8 mild steel. The close up shows the slow running cable terminated on the fixing bolt
- PB080004.JPG (128.89 KiB) Viewed 2583 times
- PB080008.JPG (128.74 KiB) Viewed 2583 times
- martinjames
Thanks. Photos were a great help. Have managed to buy a set of the correct HV3 carbs.
