Shock absorber problem
Can someone suggest a repairer (or repair) for Lumax shockers? One has ceased working on rear of car (oil level fine).
Ian (MaxMG)
Ian (MaxMG)
Re: Shock absorber problem
Depends where you are. If in the UK Stevson overhauled and repaired all four of my Girlings last year (he does Luvax as well). Not particularly cheap at £700 and his paint job is a bit rubbish, but they work fine.
If in the US. Send them to Worldwide Auto, Madison, Wisconsin. Not cheap either but his work is first class.
www.nosimport.com 800-362-1025
Marv Proctor
Rockford, IL TC5141
Marv Proctor
Rockford, IL TC5141
In the Western US, contact me for a rebuild source. Back east, Worldwide does great work.
Thanks for your responses. I'm UK so I'll give Stevson Motors a try, thanks antijam. I have drained the faulty one, removed the endcaps and now the pistons move freely, but re-assemble and fill up and no resistance. So it looks like a job for the experts and another hole in the pension!
Ian, MaxMG, Isle of Wight
- Richard Withington
Try Raj Pattel in Leicester, he can rebuild shock absorbers replace link bushes etc. tel 0116 244 8103
No fancy reception etc. !!
I can also recommend Raj. Rebuilt four Luvox dampers and replaced rubbers and pins for under £300 about two years ago. Taking two more Luvax dampers to him tomorrow. He rebuilds for Moss and NTG.
Cheers
Ian
Cheers
Ian
Dropped off Luvax dampers to Raj in Leicester today. Will take approx 3 weeks and cost £65 to rebuild each damper and £20 for each link bush. A total of £210
Checked when my last ones were done and it's almost 5 years and the car is still not finished. Time flies when you're enjoying yourself !
Ian
Ian
