TC9806 for Sale
TC9806 for Sale
]After several years of "dithering", I have finally decided the time is now to sell the TC[attachment=0]1949 MG TC Special For Sale.docx[/attachment
- TC 9806 For Sale.pdf
- (389.3 KiB) Downloaded 309 times
- 1949 MG TC Special For Sale.docx
- (227.11 KiB) Downloaded 293 times
Re: TC9806 for Sale
Jim - slick, and the best of both worlds! It's rare that one sees a nice, fully-sorted TC. Bravo!
May I assume the "Norwitt/Westlake C.I." head is somehow related to a Laystall Lucas head? I have never heard of a "Norwitt/Westlake C.I." head, and would be delighted to learn more about it.
Does the stock bonnet close all right with the offset head? What sort of header do you use, and what cam?
MGT Repair.
MGT Repair.
Re: TC9806 for Sale
Tom-Norwitt was a race shop that operated in the San Francisco bay area in the 50's and 60's and modifies stock cast iron heads for competition, mostly with heavy milling of the head and larger valves. It is marked as having a 10:1 compression ratio. I had the combustion chamber further modified as shown in drawings by Harvey Westlake to improve flow. I run wth a .125 solid copper head gasket to reduce compression. I should post a copy in the tech section.
I modified the bonnet to have a removable "bubble" cover over the carbs. It sort of matches the generator cover on the other side. I have "detuned" the engine to a stock cam (I have a 3/4 race cam and it is included in the sale). The header is a custom build but is very similar the a Derrington.
Hope this helps. I have a number of photos showing the engine if you need them.
Re: TC9806 for Sale
Jim - all very useful and helpful information. I will try the Westlake mod on my next cylinder head job - thanks for posting the drawings.
Gratefully, Tom
Gratefully, Tom
