Please would someone remind me into which hole on the underside of the TA petrol tank the reservoir line goes.
Thanks. Mike TA, Lisburn N.Ireland
TA fuel Tank outlet
Re: TA fuel Tank outlet
Mine was on the outlet nearer the centre but the important thing is to connect the reserve to the outlet with the filter. The main goes to the pipe which is a couple of gallons above the bottom of the tank, they can be seen with difficulty using a torch through the filler.
Chris
1937 TA1643 Ex Police
1966 Jensen C-V8
1966 Jensen C-V8
Huh? In the TA there is a reserve, is there on the TC (that I am restoring)? I only have one fuel line to the carbs.
I have two holes on the bottom of the tank. One I assume is a plug and one for the filter/feed line. Does it matter what hole is used for each?
Thanks, pat
Thanks, pat
Yes the TA has a selector on the dash - it does mean that you don't need the extra copper pipe from the tank or the changeover valve - you get the low fuel warning instead.
Chris
1966 Jensen C-V8
1966 Jensen C-V8
