speedo correction
jamesmdavis
speedo correction
Post by jamesmdavis » Sun Jan 22, 2017 8:28 am
Good Morning Group - I am about to change out the rear end gear ratio from 5.125:1 to 4.625:1 for better driving characteristics. ( It is supercharged.) How does one go about changing the speedo/trans to acomodate this change to maintain accurate speed indication? Thanks in advance.
Jim Davis
TC 7225
Houston
Re: speedo correction
Post by Tom Lange, MGT Repair » Sun Jan 22, 2017 9:01 pm
You either send your speedo to one of the rebuilders, and tell them which ratio you now have, and hope.
Or, you contact Speedograph Richfield in the UK, give them the ratios, and they will make up an adapter. (There is someone in the US who does this, but I forget who.)
If that's too much money, I use a grease pencil on the speedo glass, to mark the new mph in 3rd and 4th gears.
jamesmdavis
Post by jamesmdavis » Mon Jan 23, 2017 6:16 am
Tom - Would that be APT Instruments?? Jim
Post by Tom Lange, MGT Repair » Wed Jan 25, 2017 11:21 am
Post by Steve Simmons » Wed Jan 25, 2017 1:01 pm
Tom Lange, MGT Repair wrote:Or, you contact Speedograph Richfield in the UK, give them the ratios, and they will make up an adapter. (There is someone in the US who does this, but I forget who.)
Butch Taras makes them here in California.
