Transmission Gear Lube for 47TC
LFD059
Post by LFD059 » Tue Jun 06, 2017 7:51 am
Had a recommendation to use Schaffers - 293 Supreme Gear Lube 75W-90 for the transmission, however checked with the manufacturer who said No, as it's not classified as GL4. In checking around I found the brand Amsoil - Synthetic manual Transmission and Transaxle Gear Lube 75W-90 GL 4. Anyone have experience with this or other good GL 4 Gear Lube?
TC2177
Re: Transmission Gear Lube for 47TC
Post by frenchblatter » Tue Jun 06, 2017 9:38 am
I thought it should be 140W but, of course, I could be wrong.
Post by Steve Simmons » Tue Jun 06, 2017 10:26 am
The manual calls for 140. I run a straight 140 oil from Stay-Lube but may change to Redline to see if there is a difference in performance, as reported by others.
Post by frenchblatter » Tue Jun 06, 2017 11:15 am
I get mine from a local tractor dealer.
