Body plate
RJE
Body plate
Post by RJE » Sun Feb 25, 2018 5:03 pm
Hey everybody,
I am looking for an early model body plate without the 2 boxes that the information was stamped in. My car is TC 1013, and I am assuming that a plate without the boxes is correct for my year vehicle. Any input would be appreciated.
Cheers,
Ron
Tim Jackson
Re: Body plate
Post by Tim Jackson » Mon Feb 26, 2018 1:43 am
Doug Pelton has these, with your ID numbers added, if requred (here)
1946 TC0999 / XPAG 1638
restore note
RJE
Re: Body plate
Post by RJE » Mon Feb 26, 2018 7:11 am
Tim,
Thank you very much. Does my car, TC1013 require the plate without the boxes or with the boxes that have the numbers stamped within ?
Thank you,
Ron
Tim Jackson
Re: Body plate
Post by Tim Jackson » Mon Feb 26, 2018 8:58 am
Your TC1013 was built on 28 June 1946 for export to USA, three days after my TC0999 (home market). ID plates were stamped with the chassis and engine number. Here’s mine:
restore note
Re: Body plate
Post by Duncan M » Mon Feb 26, 2018 10:57 am
I think Ron is looking for the body number plate that gives the B280 body type, and then a unique number to the specific car. Early ones had no box outline where the numbers were stamped, and later style did. Towards the bottom of the article here:
https://fromtheframeup.com/uploads/TT_I ... ds__TC.pdf
I think the question from Ron is what the cut off date is for the early style body type/number plate?
Tim Jackson
Re: Body plate
Post by Tim Jackson » Tue Feb 27, 2018 1:33 am
TC0999 has the second version of the body plate described by Doug. Being made in the same week, TC1013 would almost certainly be the same.
restore note
RJE
Re: Body plate
Post by RJE » Tue Feb 27, 2018 8:11 am
Tim and All,
Thank you very much.. that is exactly what I needed..
Ron
Re: Body plate
Post by frenchblatter » Sun Mar 04, 2018 3:25 am
Whilst we're on the subject of body plates has anyone got a picture of where they go. I removed mine when a rebuilt the car and can't find a picture that shows where it goes. Plenty of pictures around, but so far all are so close up they aren't showing where they go.
Hope I've made myself clear, it'll make a change if I have.
Tim Jackson
Re: Body plate
Post by Tim Jackson » Sun Mar 04, 2018 5:00 am
It goes here:
restore note
Re: Body plate
Post by frenchblatter » Sun Mar 04, 2018 2:15 pm
Tim, many thanks, mine will be put there as soon as the weather gets warmer.
mejarch
Re: Body plate
Post by mejarch » Sat Mar 10, 2018 1:42 pm
My Body Plate is missing, so how can I find out what the original Body Type and Body No. were? Any information greatly appreciated, so I can have Doug Pelton make me a new one.
Thanks!
RJE
Re: Body plate
Post by RJE » Sun Mar 18, 2018 6:42 am
Thank you very much to all that responded.. I will call Doug right away and have one made, and install soon..
Ron
