TC Fuel Tank
TBrad
TC Fuel Tank
Post by TBrad » Thu Mar 29, 2018 10:35 am
I’m missing something trying to remove the gas tank. I can move it, but it looks like it is secured into the fenders were the two rubber bushings are on the side of the tank. I hate trying to force something. I removed the straps and the spare tire carrier along with the fuel line. I’m missing something. There is a bolt through the fender well. I thought that just held the rubber bushing in place. Does it go all the way into the tank? Are there some other hidden bolts or am I just not pulling hard enough?
If you don't know where you are going, any road will take you there!
- Brad P.
TD/C21325
TC0777
Re: TC Fuel Tank
Post by Duncan M » Thu Mar 29, 2018 11:23 am
There is a captive nut that the bolt threads into on each side of tank. The Moss catalog can be of use to show this.
https://mossmotors.com/gas-tank
TBrad
Re: TC Fuel Tank
Post by TBrad » Fri Mar 30, 2018 6:28 am
It turns out the "builder" used studs instead of a bolts to attach the the tank to the fenders. I resorted to the double-nut technique to extract. Now it's off to the repair shop.
- Brad P.
TD/C21325
TC0777
TBrad
Re: TC Fuel Tank
Post by TBrad » Fri Mar 30, 2018 7:33 am
Split pins to hold the bottom fuel tank pads to the frame?
- Brad P.
TD/C21325
TC0777
