Could someone verify that the threads on the rear axle housing are 1.9/16" diameter 16 tpi 55 degree Whitworth form? It would be very much appreciated.
James Davis
TC 7225
Houston
Rear Axle Housing Threads
Re: Rear Axle Housing Threads
Hi James,
I always assumed that this would be a metric thread, 40mm diameter as this is the ID of the bearing. I tried a metric thread gauge 1.5 mm pitch and it would not fit. The diameter of the thread is also less than 40 mm. I then used an imperial thread gauge and the 1/16 thread whitworth form fits perfectly(16 tpi) and the OD is 1 and 9/16". So I agree with your assessment of the thread form and size.
Max Irvine
TC 9375
Max Irvine
TC 9375
Thanks so much for the verification.
James Davis
TC 7225
Houston
James Davis
TC 7225
Houston
