Grill to cowl fasteners
I had an unsuccessful afternoon trying to unsolder the screws that hold the grill in-place on the cowling, so I could move them to correctly align with the new grill (slats). I tried my soldering iron and I tried a Benzomatic, to no avail. I don't want to overheat or discolor the chrome cowling in the process. Any suggestions?
If you don't know where you are going, any road will take you there!
- Brad P.
TD/C21325
TC0777
- Brad P.
TD/C21325
TC0777
Re: Grill to cowl fasteners
Brazing is pretty much the preferred method I believe Brad. It does discolor the chrome finish but in my case the only stud needing repair was on the bottom. so with some buffing and fine compound stick it came out ok. A high strength epoxy or similar solution may be available. Vibration is your enemy. Good luck!!!!
Thanks Marv.Marv wrote:Brazing is pretty much the preferred method I believe Brad. It does discolor the chrome finish but in my case the only stud needing repair was on the bottom. so with some buffing and fine compound stick it came out ok. A high strength epoxy or similar solution may be available. Vibration is your enemy. Good luck!!!!
- Brad P.
TD/C21325
TC0777
- Brad P.
TD/C21325
TC0777
