Re: MG TA1932 in Germany - Tacho, Speedo, Steering, Oil Pres
o today i done a little bit
i cleaned the old fan and spray it in red , the same color as the engine and fixed it again
also i painted the MG signs red too
some other parts you can see on the pictures i fixed to the car
i have to ask my son for the videos, to compress them, the sound of the new exhaust, much better
Today I was in Essen - techno classica,
but there was only 4 MG t types there,
even a few stalls where you could buy spare parts,
extremely many very high priced cars
I actually wanted to buy an overflow line for the carburettor, unfortunately not possible .
Home again, really cold, 3 ° , then I changed the break pipe/hose in the front ,
the screws were really tight, for the first time was 1 hour not so bad,
now the car is safe again for the next ride.
so today
i take off the cover from the carburettor,
it seems to have a hole for the ticker
but it is closed inside, no hole as it seemd to be
no ticker in the future
also one idea for the 2 score what shoudn t be on the cover
so i can t make an overflow as it is now....
next step was the fuel line
horrible fuel hoses
now a new fuel copper line
and it is tight
between the carburettors i will make it new at the weekend
also copper line
here a picture from this evening
horrible fuel hoses
and it is tight
also copper line
so today i got my brass
so i could use my lathe the second time,
have had a look to the instruction so i can tunr all parts of the lathe, don t know how to explain it
i wanted to make a rejuvenate part for the knob
and not bad the first difficult part for a lathe beginner.
i have a thread on the backside so i can assemble it really easy
in some month i will engrave it with my stepcraft 420
other parts for the new overflow ist still on shipping
the ignition light is in the position of the fuel reserve knob, so i have to look what i can do,
not a new hole in the dashboard
i should be nearly original in the future
- 200419 Reserveknopf.JPG (22.01 KiB) Viewed 46214 times
Reserve knob works
a little bit more problems than i thought,
i have to rebuild the holder for the reserve part at the engine
but now it is ok
perhaps i will make the knob itsself a little bit smaller
next winter, firt i will see if all works like it should
tomorrow i will polish it ;-)
but now it is ok
a new part for my printer ?
40 gr not to much ;-)
a little bit work while looking TV
a booring show
FHT is my full name
a booring show
FHT is my full name
today some problems with printing, tomorrow next one
but new ignition cable
and the lower part of the toolbox was missing
so i do it today.
and with my new lathe i prepare the nut for the overflow banjo with the new thread cutter 1/4 BSF
so i do it today.
overflow ready
some parts polished
prepare the cover...
and fuel line , the old one
i will make a fake thiker in brass next days.
car is running
some parts polished
car is running
Hallo
the first print of my neew spark plug holder, own desing with my name FHT
is here.
some small changes i have to do, but it will be fine.
one layer does not hold and the thread isn t designed
i will put red colour to the ground of the logos
so if somebody need one ;-)
is here.
so next step
nearly ready
here without painting
the logos will be painted tomorrow
half done now ;-)
perfect sun
so fast painting ;-)
ready as i want it.
nearly ready
half done now ;-)
perfect sun
ready as i want it.
Re: MG TA1932 in Germany - rebuild tools 3d Design
and now i know how to design a thread and a parametric logo
someone an idea what i should to design next ?
the next one is ready
for a friend how has seen it ;-)
the logo is now 2mm nnot 1,2 so it looks better
so i have to print a new one for me
the logo for your name is in germany not so good
perhaps in some month, when i have learned to use my new stepcraft in aluminium
Yes, the same reason why Swallow Sidecar became Jaguar!
so next step to make the car more original.
i changed the security Bosch ignition coil to a Q12 repro Coil,
the original switch on the dashboard i will rebuild next winter,
the car starts perfect, i small round with the car is ok
so today i closed the hole in the toolbox, all painted parts of the car i coverd with thick wet scarf
mig welding
dangerous but i had luck, all ok afterr work
painted with zinc
in 2 or 3 weeks i will make a little air brush with the red colour to finish this step
than i put my 3d printed spark plug holder to this place
now printed with a thread for the plug
mig welding
painted with zinc
so
next step ready
not to bad i think
the new individual 3d printed spark plug holder
A.V. it is on the way to you ;-)
next step ready
not to bad i think
- SavannahDog
Franz, I would like one. I'll send you a private message.
Julian Carter
1948 MG TC
1952 Chevy Pickup
1967 Triumph TR4A
1970 Triumph GT6
1948 MG TC
1952 Chevy Pickup
1967 Triumph TR4A
1970 Triumph GT6
Franz, looking good!
Ken Klemmer
1948 TC 5510
1948 TC 5510
or in a universal Design
here a picture, with a spark plug flying in the octagon
before other copy the design, ;-)
ok i have taken the old octagon Design too,
but changed it to a individual design
so that you know who done it first
