Petrol tank sender float
Post by jddevel » Sat Jan 25, 2020 2:24 am
The float arm on my petrol tank sender has siezed. It would obviously help if advice from anyone else who had the problem could advise how did they freed it off?
ROGER FURNEAUX
Re: Petrol tank sender float
Post by ROGER FURNEAUX » Sat Jan 25, 2020 5:37 am
I have never had that problem, but suggest you remove it and apply penetrating oil or WD40 while gently working the arm. There are many other solvents you could use, such as acetone or alcohol.
Roger
Post by jddevel » Sat Jan 25, 2020 7:17 am
Thanks Roger. All done thanks to WD40 and wiggling the arm. Aluminium had oxodized jamming the arm. Possibly occured during previous owners long term lay-up.
