Wheel spoke thread
Wheel spoke thread
Having measured the thread on TC wheel spokes I have decided they are 5/32 Whitworth (32 tpi). Can anyone confirm or tell me otherwise please?
- ROGER FURNEAUX
Re: Wheel spoke thread
hi john - I did a quick search on Google: there is plenty of info about bicycle threads, but precious little about car spokes.
As far as I can make out, they are indeed 32tpi, whatever the wire gauge used. 5/32" is about 5mm or 6G.
The important thing about spokes is that the threads are rolled, NOT cut. Rolling deforms the metal by raising it up and is therefore much stronger then cutting with a die which removes metal. The thread form is also different with rounded valleys and peaks.
If you have a problem, simply buy new spokes and nipples, they are not expensive: try Motor Wheel Services, who make their own.
Roger
Roger
Hi Roger - thank you for that, I didn't realise that they are rolled, it makes sence when I think about it.
I need one new short spoke but could only get a long one so was going to lengthen the thread and shorten the spoke to suit. Now I will change my plan and contact Motor Wheel Services for a short spoke
- ROGER FURNEAUX
hi john - I think I have some spokes, let me know the length!
roger
roger
