TC front suspension
Geoff Hemingway
TC front suspension
Post by Geoff Hemingway » Wed Aug 21, 2013 8:40 am
Hello ...greetings from a new UK member !
I've recently acquired a '49 TC which is basically a good driver but which will benefit from a rolling restoration programme over the coming months.
Most elements of the car are totally standard with the exception of the front shocks . These have been modified to accept telescopic dampers at some time in its past life ( all spent in UK from new )
There seems to be litte data available on the web, other than it is likely that Woodhead Monroe shocks were used.
I wonder if there is a source for replacements or should I just junk them & retrofit the proper dampers to restore originality ?
Thanks in anticipation
Geoff
TC 7635
Car shows 253.jpg (48.01 KiB) Viewed 2651 times
Re: TC front suspension
Post by Steve Simmons » Wed Aug 21, 2013 9:08 am
Just my opinion, but the originals not only work just fine, they look SO much better. The front shocks on a TC are quite visible and to my eye, they just give one more reason for people to ask if it's a kit car.
Post by Gene Gillam » Wed Aug 21, 2013 12:35 pm
Yes and no, Geoff. Unlike Steve, I like the look of the tube shocks on there - and unless you are a stickler for originality and can find a *good* or *rebuildable* set of front shocks that you can afford I wouldn't worry about it. Originals do show up on eBay occasionally, but not often, and the cost is generally pretty high. I don't know of anyone carrying them right now here in the States.
Gene
