Parts needed for internal TC Differential
Post by bloodysalmon » Thu Aug 08, 2019 4:12 am
Having reviewed all my differential bits, and there are a number, but not everything so I need a few parts please, or help to find some.
The above picture shows in yellow the parts I'm after.
1. #19 are brass shims, with the picture showing 3, so I need 6 - anyone got any or knwo where to find some from?
2. #17 is a 'collapsable spacer' (i think its called that!), I need 2 of these too. If anyone has a spare to lend me, or can measure it up and draw its dimensions then that would be brilliant too. I dont have one at all but clearly is crucial to ensure proper float along with the shims.
3. #22 Confirmation to what the washer and pinion locking lock is please?
I presume these parts may have been included in quite a number of other diffs post-war ... so do you know what doners can be used and bought cheaply too? Thank you
Re: Parts needed for internal TC Differential
Post by frenchblatter » Thu Aug 08, 2019 7:26 am
Chris, have you tried Roger Furneaux. His number is 01566 784111, email roger.46tc@gmail.com
Ring after 5pm as he'll be in his workshop before that.
Good luck
Post by bloodysalmon » Thu Aug 08, 2019 7:44 am
good call Norman, yes i've had parts from Roger before so well worth a try ...
Post by Duncan M » Tue Aug 13, 2019 8:10 pm
Where is that diagram from? Does not look like TC. For instance, where are the oil seals? Bearing #15 shows an unnumbered bearing race next to it that does not exist. Moss catalog diagram is more accurate to original.
Post by bloodysalmon » Wed Aug 14, 2019 12:44 am
Duncan, this is a diagram showing the diff and not the axle ends, so no seals. Taken from remnants of the 90's Barry Walker catalogue. I suspect the collar next to #15 is an integral part of the bearing.
