Rear Wing (fender) position
Posted: Thu Aug 22, 2019 12:40 am
I've resumed my battle with getting the rear quarter of the tub correct and I'm trial fitting a rear wing. As always, I have a question:
My wing has a line of holes in it which are presumably the ones for the screws that go into the wood frame to hold the wing in place. These look original to me. However, when I line the holes up with the wood, the outer most edge of the leading edge of the wing (i.e. the bit next to the running board) sticks out wider than the running board.
If I adjust this inward so that its flush with the running board (i.e so that you could put a flat edge along the edge of the running board and it would just touch the wing), not only is it harder to get to fit the profile of the wood, but the line of screw holes ends up being out if alignment with the wood.
Looking at pictures of finished cars on the internet, I can see examples where the wing is flush and ones where it stick out wide of the running board a bit (say an inch or so). Which is correct? Note that the plan engineering drawing in TCFE which shows it flush is of a TA, not a TC, so is maybe not the right thing to reference.
