Rear main shaft bearing - Timkin number?
Posted: Mon Nov 18, 2019 12:38 pm
Hi All, yes I do have a TC but I am also restoring a '51 TD I scooped for a "stupid good deal" I hope you can help me out with. When I look at the MOSS numbers for the TC and TD the bearing numbers are not the same, but I thought... (?) that the gear box's for the TC's and TD's were the same.
Either way, I need a new rear main shaft bearing for the TD and I am unable to read the number on the original bearing so I can cross reference it to a bearing off the shelf locally.
Does anyone happen to know what a modern bearing number (Timkin?) would be?
Thanks, Pat
Thanks, Pat
