MGTF performance issue
Posted: Wed Nov 27, 2019 11:26 am
Hello Group,
This is a follow up to an earlier post in which I requested assistance on installing pistons in this TD block.That job is happily done.This engine is .060 in..oversize at the bores but was rebuilt not too long ago.however the carbs were very rich which I believe washed down the cylinders and prematurely wore out the rings.Cylinders measured out correctly new rod bearings were installed.Piston ring gap was within spec and we had a new set of valves and springs and guides installed and valve seats refaced.Engine no longer smokes and compression is an even 145 lbs.across all cylinders.New spark plugs,Champion na8.This is a TF head.
Distributor has Petronix ignition and we replaced the stretched out springs for the advance.Timing is set at 8 degrees btdc @idle.Cap,rotor and wires are good.
This engine has a B and G race cam and we were advised to adjust the valves to .015 in..,hot.
We rebuilt the carbs with rebuild kits from Moss.Used standard needles for the TF carbs,GJ.Engine idles smoothly and accelerates properly in the shop.
The problem:When driving on the road,if you accelerate normally,the engine breaks up and will not accelerate.However,if you are very gentle on the throttle pedal and give it gas slowly you can accelerate smoothly throughout all gears with no performance issues until you reach high gear which needs more throttle to accelerate and then hesitates slightly.
Book calls for a float adjustment of 3/8 in.but carbs tended to flood,so I set them at 7/16 in.and they no longer flood.
Not sure where to go next and would appreciate any advice.
Thank you and Happy Thanksgiving.
