TC tappet clearance-fast road cam
Posted: Sat May 18, 2013 5:54 pm
by Ross Taylor
I have just started up the new motor in TC4284 . After a couple of minutes running the water pump seal let go so I am waiting for a new unit from Doug Pelton ( should arrive tomorrow ), when in the UK I purchased a fast road cam from the Octagon Car Club . Can anyone advise me of the recommended tappet clearances and the valve timing for this cam ?
Re: TC tappet clearance-fast road cam
Posted: Sun May 19, 2013 3:53 am
by Max Irvine
G'day Ross,
Did you ask the Octagon Car Club if they have this information? If they sell it they should have the info or be able to tell you where to get it.
Posted: Tue May 21, 2013 7:52 pm
by Rick Waters
When I purchased the Crane cam for my XPAG, it came with a data and spec sheet that gave the valve clearance information. (18 thou inlet, 20 thou exhaust, as near as I can remember).
And yes, I left the ".019" brass plate on the valve cover, as it is the average, right?
Posted: Wed May 22, 2013 4:32 am
by Ross Taylor
OK
Rang the Octagon CC last night
Cam 70 38 overlap 110 degrees tappet clearance 0.012
any suggestions to what I have installed.
