TC front suspension
Posted: Wed Aug 21, 2013 8:40 am
Hello ...greetings from a new UK member !
I've recently acquired a '49 TC which is basically a good driver but which will benefit from a rolling restoration programme over the coming months.
Most elements of the car are totally standard with the exception of the front shocks . These have been modified to accept telescopic dampers at some time in its past life ( all spent in UK from new )
There seems to be litte data available on the web, other than it is likely that Woodhead Monroe shocks were used.
I wonder if there is a source for replacements or should I just junk them & retrofit the proper dampers to restore originality ?
Thanks in anticipation
Geoff
TC 7635
Geoff
TC 7635
