TC generator front plate
Posted: Sat Sep 07, 2013 11:41 pm
Can the front plate on a TC generator be successfully welded? The mounting hole on mine is very worn so needs to be repaired. I am not sure if the plate is steel or cast iron. If it is cast I will have to braze it up.
