My single carburetter TC
Posted: Sun Oct 13, 2013 6:37 pm
Having owned my TC for just on 2 yrs and being constantly plagued with vapour lock problems thought that I would finally order a heat shield.
In preperation I re ajusted the braided fuel line so that it was further from the exhaust manifols and even on both sides only to discover that on start up it leaked like a severed artery.
I rolled the car back into my garage and thought since my car was going nowhere would remove air filter and balance pipe in preperation for when the heat shield would arrive.
The pistons looked pretty dirty on the carburettors and that was when I discovered that the front one was stuck solid !
I had often wondered whether my car was runnin g at peak performance as seemed to run out of breath at 4000 revs but always ran ok below those revs and on the open road.
The piston was eventually freed and cleaned as was the good one and with a small minature grinder was able to remove crimped ends off the braided fuel line and make one up with rubber fuel line as I was eager to see how the car now performs.
Instant start up and will rev to 5000 revs and more sporty performance so wonder now whether my vapour lock problems have been cured as it was always the 2 rear cylinders that had cold plugs.
New braided lines have been ordered as the hose from the fuel pump had been repaired in a similar fashion .
Ian theobald.
Ian theobald.
