Possible modifications to your car
Posted: Sun Dec 08, 2013 4:00 pm
Recent discussions on http://groups.yahoo.com/neo/groups/mg-tabc/info
regarding modifications, included the following:
1 VW STEERING – Don’t knock it till you’ve tried it!
2 NEW STUB AXLES IN THE FRONT SPINDLES – Invisible and safer.
3 TAPERED BEARINGS IN THE FRONT HUBS - Invisible
4 TAPERED BEARINGS ON THE PINON GEAR – Invisible and more durable.
5 MODERN TAPERED BEARINGS ON THE RING GEAR - Invisible
6 NUTS WITH LIP SEAL ON REAR AXLES – Invisible and better seal.
7 MODERN SEALED BEARINGS ON REAR AXLES – Invisible and better seal.
8 MODERN STEEL REAR AXLES – Invisible and stronger.
9 LED TAIL LIGHTS – Invisible except when used.
10 SPIN ON OIL FILTER – Simply better filtering.
11 PETRONIX IGNITION – Almost invisible and less maintenance.
12 CHROME/STAINLESS STEEL WIRE WHEELS – Chrome not correct, but…..
13 FIRESTONE TIRES – Less expensive and better wear than original.
14 COMBINATION OIL PRESSURE/TEMP GAUGE – Just more practical.
15 RELOCATE OIL PRESSURE/TEMP GAUGE AND AMPS GAUGE (SWITCH LOCATIONS) - This can be argued, but it made sense to me since the gauge nearest the steering wheel is obscured by the left hand when driving.
16 FOUR CORE RADIATOR – Almost invisible, but superior cooling.
17 WATER PUMP WITH BRONZE 4 BLADE IMPELLER – Invisible with better cooling.
18 MGB FAN BLADE – Noticeable but less vibration and better cooling.
19 FLEXIBLE OIL LINES FROM OIL PUMP TO FILTER TO BLOCK – Noticeable, but more durable.
20 BROOKLANDS SCREENS – Noticeable but Period Correct.
21 BROOKLANDS STEERING WHEEL – Noticeable but Period Correct.
22 LUGGAGE RACK – Period correct accessory.
23 TALLER GEAR RATIO IN PUMPKIN – Invisible but more practical on today’s highways.
24 ENGINE BORED – Invisible and was necessary.
25 ROLLER CAM? – I have not done this yet, but plan to. Invisible but more durable and more power.
26 IMPROVED REAR MAIN BEARING SEAL – Invisible but better seal.
27 MIDGE ON RADIATOR CAP – Period Accessory.
28 POLYURETHANE BUSHING IN SPRINGS – Almost invisible, but better handling.
29 TRIPOD HEADLIGHTS – Period accessory.
30 DUO TONE PAINT – Prewar style. No excuse, I just liked it.
31 BONNET STRAP – Period correct for racing, and I happen to like it.
32 solid state conversion to fuel pump offered by Burlen Fuel Systems
33 solid state voltage regulator conversion by Bob Jeffers of Wilton Auto Electric in 2009
34 Panhard rods, front and rear to keep lateral suspension movement to a minimum.
35 Replacement of the tie rod ends with rose joints for added security and steering feel
36 replace felt with rubber
37 add center console (as described on "Resources" page on this website
38 modify thermostat housing to accept modern thermostat
