I see that From-the-frame-Up sells a fiber/ paper washer which is supposed to be used with the ignition/ light switch .
Does it go under the bezel on the front side of the panel or behind the gauge under the wire clip?
Thanks,
Brian W.
Ign. Light switch fiber washer
