installing the pedal fume excluder rubber
Posted: Sun Mar 02, 2014 9:45 am
by LaVerne Downey
I know it was a b%%% on the TD and TF ..even with the pedals removed. So whats the best way to go about it on the TC ?
Re: installing the pedal fume excluder rubber
Posted: Sun Mar 02, 2014 10:25 am
No easier, but you can do it with the pedals on. Use lots of lubricant and slip it over the pedals. It will stretch to the point that you're convinced the rubber will tear, but it never does. No promises of course, but I've never seen one split. I seem to remember using a light oil, but some use KY or similar. I figure whatever you use, you'll want to clean it out afterward so it doesn't collect road grime inside the boot.
Posted: Mon Mar 03, 2014 7:18 am
by LaVerne Downey
Thanks Steve I'll have a go at it this morning.
Posted: Tue Mar 04, 2014 9:04 am
by Gene Gillam
Good luck LaVerne...KY works great. Ditto on never splitting one.
Posted: Tue Mar 04, 2014 11:23 am
by LaVerne Downey
I've got it on..tackling some new felt padding for the rear wheel arches right now. Still not sure about the side curtain box.
