I am in the process of removing the front quarter panel on my TC project. There is a lip on the very front of the front of the front quarter panel, how is this front vertical (angled a bit backwards) lip held in place? Is it sandwiched between the front side rails? I can't see any nails visible.
Thanks, Pat
Removing TC front quarter panel question
Re: Removing TC front quarter panel question
Yes it is, if you remove the rails you can get at the pins that hold the quarter panel in place.
