SU Pump Puzzle
Posted: Tue Nov 30, 1999 8:07 am
by Skip Burns
Apologies. It's not my intent to hog space, but I've got a problem. About a month ago, during a rallye, I experience fuel pump failure. I whacked it a couple of times, but it refused to work. After trailering the car back to my garage and letting it sit for several days, I discovered the pump was working again. So I drove it again for roughly 30 miles when, during a night drive, it failed again. Fortunately there was a freeway offramp and I was able to coast into a parking lot. By now I was not very happy with this pump. The car was put back in the garage where it sat for about two weeks while I pondered the situation. Today, on a hunch, I turned the key on. The pump is working again!
If anyone has a clue about what's going on with this Lucas pump, I'd be most grateful if you'd advise me on what the problem is. I'm at a loss to explain this one.
Cheers, Skip
Re: SU Pump Puzzle
Posted: Tue Nov 30, 1999 9:00 am
by Geoffrey WHEATLEY
Skip...try cleaning the points on your Lucas pump, if corroded they will work for a limited time then give up as the points get hot. Clean them and you may be lucky..if not change the pump!
Regards Geoff
Re: SU Pump Puzzle
Posted: Tue Nov 30, 1999 9:29 am
by Bill Traill
Skip,
Is it possible the gas tank filler cap is not venting and the pump is stopping when it pulls a vacuum on the tank. Later, air leaks in and then the pump works.
Bill Traill
Re: SU Pump Puzzle
Posted: Tue Nov 30, 1999 10:23 am
by Bob and Carolyn Grunau
Hi Skip, you may have a partially plugged tank suction filter or line and/or plugged fuel filters in the pump or carbs. Also check the gas cap is venting. Any of these conditions will allow the pump to operate for a time then stop as the suction becomes too high for the pump to operate against. Standing for a time allows the fuel to seep through the obstruction and the pump may operate again for a short time. Next time the pump quits, check the pump temperature, if its very hot, probably a plugged line/filter. Otherwise, the SU pump may just be old like the rest of us and needs to be rebuilt or replaced.
Bob
Re: SU Pump Puzzle
Posted: Tue Nov 30, 1999 11:23 pm
by KENNETH PORTER
Skip:
I would bet that the fuel filter at the bottom of the gas tank is the culprit. It's one of those things that never gets cleaned because it is so inconvenient. I cleaned mine last spring. It was so full of decades of crud that I don't know any fuel got through it at all.
Ken TC 4147
Re: SU Pump Puzzle
Posted: Tue Nov 30, 1999 11:50 pm
by CFritz7001@aol.com
Yep, sounds all too familiar. The strainer at the fuel tank outlet on my TC was so cruddy I couldn't believe it could pass any fuel at all. Fact is, I didn't even know there was a strainer there until it stopped up completely!! I never have found any mention of his strainer in any of my books.
Regards,
Carl Fritz
Re: SU Pump Puzzle
Posted: Fri Dec 03, 1999 7:07 am
by Ray McCrary
Hi guys,
I had the same problem after flushing and sloshing my tank.....The strainer clogged and gave new meaning to "what the f**k NOW!!!!"
Ray McCrary
"Speed is Life"
